  • 1 Vote(s) - 1 Average
Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know)
#41
The two side by side connected to the resistor, one is not negative to ground, and the resistor is not the correct valuei if I am reading the schema correctly. All three negative go to ground, one at least is not.
RE: Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know) - by radio1 - 10-02-2022, 07:51 PM
There are currently 10331 online users. [Complete List]
» 2 Member(s) | 10329 Guest(s)
