  • 1 Vote(s) - 1 Average
Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know)
#47
Excuse me not rectifier. They're hooked to the large black cap on the top side of the radio.
RE: Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know) - by RetroRev - 10-02-2022, 08:46 PM
There are currently 3823 online users. [Complete List]
» 1 Member(s) | 3822 Guest(s)
