40-180 Volume Issue
I'd start by cleaning the tube socket. Spray some contact cleaner or DeOxit in the socket and work the tube in and out a few times. Might not be a bad idea to do this to all the tube sockets. That you can do without removing the chassis. Let the radio sit for at least 15 minutes before trying it to allow the cleaner to evaporate. If that doesn't clear up the problem, you'll have to pull the chassis and try spraying some cleaner into the volume control itself under the chassis.
These things may or may not clear up the problem but try the easy stuff first!
40-180 Volume Issue - by mkharks - 10-03-2022, 10:48 AM
RE: 40-180 Volume Issue - by NostalgiaRadioTime - 10-04-2022, 12:41 AM
RE: 40-180 Volume Issue - by GarySP - 10-04-2022, 09:45 AM
RE: 40-180 Volume Issue - by mkharks - 10-04-2022, 10:46 AM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 2432 online users. [Complete List]
» 2 Member(s) | 2430 Guest(s)
