Philco Model 81B
Hi Texan George,
This radio uses 4 tubes, so there should be a lot of transformers from early 30s Philco 4 or 5 tube sets that will work on this Unit. This set uses 6V tubes and an 80 rectifier with its own 5V heater. I would think that the 80, 81, and 37-84 transformers should be electronically similar. even some of the 5 tube sets should work. If you found someone that got so )!$$ed off at their 89 from #&!! that they threw it against a wall, that transformer should work.
If you are trying a transformer from a non-Philco, The Donor set should:
-Be a 5 tube set (The 42 filament draws much more current than a 41, 6V, etc.
-Use an 80, 5Y3, 5Y4,5W4, etc. rectifier. Transformers from Philcos that used an 84 or similar rectifier
won't work unless you rewire the rectifier socket for an 84.
- Use an electromagnetic dynamic speaker. connected in the B+ circuit. The output from the Rectifier
secondary is higher, to account for the field coil.
- Be physically able to fit.
Good luck.
Philco Model 81B - by texan george - 09-25-2022, 03:36 PM
RE: Philco Model 81B - by Radioroslyn - 09-25-2022, 07:49 PM
RE: Philco Model 81B - by David - 09-25-2022, 08:14 PM
RE: Philco Model 81B - by texan george - 09-25-2022, 08:24 PM
RE: Philco Model 81B - by texan george - 09-30-2022, 04:51 PM
RE: Philco Model 81B - by Radioroslyn - 09-30-2022, 10:32 PM
RE: Philco Model 81B - by texan george - 10-01-2022, 05:16 PM
RE: Philco Model 81B - by MrFixr55 - 10-01-2022, 05:40 PM
RE: Philco Model 81B - by Radioroslyn - 10-02-2022, 08:18 AM
RE: Philco Model 81B - by texan george - 10-02-2022, 08:42 AM
RE: Philco Model 81B - by falcon123 - 10-02-2022, 09:49 AM
RE: Philco Model 81B - by texan george - 10-02-2022, 01:05 PM
RE: Philco Model 81B - by Radioroslyn - 10-02-2022, 02:36 PM
RE: Philco Model 81B - by texan george - 10-02-2022, 05:05 PM
RE: Philco Model 81B - by Radioroslyn - 10-02-2022, 06:13 PM
RE: Philco Model 81B - by texan george - 10-03-2022, 01:17 PM
RE: Philco Model 81B - by radiorich - 10-03-2022, 02:30 PM
RE: Philco Model 81B - by texan george - 10-04-2022, 05:09 PM
RE: Philco Model 81B - by MrFixr55 - 10-04-2022, 10:12 PM
RE: Philco Model 81B - by texan george - 10-05-2022, 07:27 AM
RE: Philco Model 81B - by texan george - 10-21-2022, 02:55 PM
RE: Philco Model 81B - by radiorich - 10-21-2022, 03:24 PM
RE: Philco Model 81B - by Radioroslyn - 10-21-2022, 04:34 PM
RE: Philco Model 81B - by texan george - 10-22-2022, 06:26 AM
RE: Philco Model 81B - by texan george - 10-22-2022, 06:28 AM
RE: Philco Model 81B - by texan george - 10-22-2022, 02:19 PM
RE: Philco Model 81B - by texan george - 10-22-2022, 03:52 PM
RE: Philco Model 81B - by Radioroslyn - 10-22-2022, 08:43 PM
RE: Philco Model 81B - by Radioroslyn - 10-22-2022, 08:50 PM
RE: Philco Model 81B - by texan george - 10-23-2022, 04:45 PM
RE: Philco Model 81B - by Radioroslyn - 10-23-2022, 09:22 PM
RE: Philco Model 81B - by texan george - 10-25-2022, 05:46 PM
RE: Philco Model 81B - by texan george - 11-04-2022, 11:25 AM
RE: Philco Model 81B - by Radioroslyn - 11-04-2022, 12:58 PM
RE: Philco Model 81B - by RodB - 11-05-2022, 09:18 AM
RE: Philco Model 81B - by radiorich - 11-05-2022, 11:49 AM
RE: Philco Model 81B - by texan george - 11-05-2022, 03:26 PM
RE: Philco Model 81B - by texan george - 11-08-2022, 12:48 PM
RE: Philco Model 81B - by radiorich - 11-09-2022, 02:00 PM
RE: Philco Model 81B - by texan george - 11-10-2022, 12:09 PM
Users browsing this thread: 27 Guest(s)
