Philco 39-80B
An update:
Chassis has been re-capped and all resistors replaced.
Veneer places re-glued and repaired as needed.
Started on Battery Eliminator power supply, waiting on transformer to arrive
Photo is a trial fit, new grill cloth installed, new bezel cover and waiting on new dial face.
Missing one knob, any advice where to look ?
Best wishes.
Philco 39-80B - by cry42 - 09-18-2022, 04:36 PM
RE: Hello from Whitney Texas - by GarySP - 09-18-2022, 05:52 PM
RE: Hello from Whitney Texas - by cry42 - 09-18-2022, 06:01 PM
RE: Hello from Whitney Texas - by David - 09-18-2022, 07:43 PM
RE: Hello from Whitney Texas - by Radioroslyn - 09-18-2022, 07:44 PM
RE: Hello from Whitney Texas - by klondike98 - 09-18-2022, 10:14 PM
RE: Hello from Whitney Texas - by radiorich - 09-19-2022, 12:55 AM
RE: Hello from Whitney Texas - by cry42 - 09-19-2022, 09:53 AM
RE: Hello from Whitney Texas - by Eliot Ness - 09-19-2022, 12:33 PM
RE: Hello from Whitney Texas - by MrFixr55 - 09-19-2022, 08:25 PM
RE: Hello from Whitney Texas - by cry42 - 09-20-2022, 07:30 PM
RE: Hello from Whitney Texas - by Radioroslyn - 09-20-2022, 07:51 PM
RE: Hello from Whitney Texas - by cry42 - 09-20-2022, 08:31 PM
RE: Hello from Whitney Texas - by cry42 - 09-21-2022, 06:33 PM
RE: Hello from Whitney Texas - by David - 09-21-2022, 07:58 PM
RE: Hello from Whitney Texas - by MrFixr55 - 09-21-2022, 08:42 PM
RE: Philco 39-80B - by RodB - 09-22-2022, 09:24 AM
RE: Philco 39-80B - by cry42 - 09-24-2022, 05:39 PM
RE: Philco 39-80B - by RodB - 09-24-2022, 07:27 PM
RE: Philco 39-80B - by cry42 - 10-05-2022, 12:49 PM
RE: Philco 39-80B - by cry42 - 01-08-2023, 08:49 PM
There are currently 10632 online users. [Complete List]
» 2 Member(s) | 10630 Guest(s)
