Philco 16B restoration
There does seem to be 2 different tone networks used on the code 121 chassis. They don't use the same rotatory switch. It would be much easier to stick with circuit it has rather to convert it to the other. https://philcoradio.com/library/download...%20165.pdf  &  https://philcoradio.com/library/download...l.%201.pdf  All 3 of the code 121's I have are like yours w/the three .003's.
Philco 16B restoration - by morzh - 08-07-2022, 02:27 PM
RE: Philco 16B restoration - by Radioroslyn - 08-07-2022, 06:49 PM
RE: Philco 16B restoration - by morzh - 10-09-2022, 09:11 PM
RE: Philco 16B restoration - by klondike98 - 10-09-2022, 09:38 PM
RE: Philco 16B restoration - by Radioroslyn - 10-09-2022, 10:00 PM
RE: Philco 16B restoration - by morzh - 10-09-2022, 10:16 PM
RE: Philco 16B restoration - by morzh - 10-11-2022, 08:28 PM
RE: Philco 16B restoration - by morzh - 10-15-2022, 09:37 PM
RE: Philco 16B restoration - by morzh - 10-16-2022, 09:52 PM
RE: Philco 16B restoration - by morzh - 10-17-2022, 08:36 PM
RE: Philco 16B restoration - by morzh - 10-19-2022, 09:13 PM
RE: Philco 16B restoration - by morzh - 10-20-2022, 07:51 PM
RE: Philco 16B restoration - by morzh - 10-23-2022, 07:04 PM
RE: Philco 16B restoration - by morzh - 10-26-2022, 02:03 PM
RE: Philco 16B restoration - by Radioroslyn - 10-26-2022, 02:12 PM
RE: Philco 16B restoration - by morzh - 10-26-2022, 10:33 PM
RE: Philco 16B restoration - by radiorich - 10-26-2022, 11:04 PM
RE: Philco 16B restoration - by morzh - 10-27-2022, 07:01 PM
RE: Philco 16B restoration - by morzh - 10-28-2022, 10:05 PM
RE: Philco 16B restoration - by morzh - 12-18-2022, 02:26 PM
RE: Philco 16B restoration - by Paul Philco322 - 12-18-2022, 05:00 PM
RE: Philco 16B restoration - by morzh - 12-18-2022, 05:29 PM
RE: Philco 16B restoration - by morzh - 12-29-2022, 03:58 PM
RE: Philco 16B restoration - by MrFixr55 - 12-29-2022, 07:30 PM
RE: Philco 16B restoration - by morzh - 12-29-2022, 08:27 PM
There are currently 7046 online users. [Complete List]
» 2 Member(s) | 7044 Guest(s)
