Philco 41-295 XXL tube voltage readings
I am having difficulty getting any reception after recapping and replacing out of spec resistors.  While I can see the expected voltages on the schematic for some tubes, others, particularly one of the 2 XXL's shows none.   Should I assume they should both be the same?  I have attached a summary of the readings I've deciphered and those I read on the set I'm on which I'm working. Is there a chart somewhere for this radio that I am missing?
Glenn
Philco 41-295 XXL tube voltage readings - by GRG - 10-16-2022, 02:17 PM
There are currently 3244 online users. [Complete List]
» 5 Member(s) | 3239 Guest(s)
AvatarAvatarAvatarAvatar
