Recent pickups - 49-501 and a 40-150
I picked up the 40-150 at the Kutztown show. Of course the buttons have dissolved but overall it's in good shape. As soon as I finish my Stromberg-Carlson 535M I'll dig in it. I recently did a 40-180 so I'll be somewhat familiar with the chassis. I also picked up a 49-501 "Boomerang" at a flea market yesterday. Still has it's back but there is a crack across the top. It's newer than my comfort zone (1935-1945) so I'm not sure what I'm going to do with it.
I was surprised to read in the January 1940 Consumers Unions Reports that the 40-150 was one of the "Recommended" radios in the $30-50 range, coming in 4th. Cool!
[Image: http://i863.photobucket.com/albums/ab191..._1284a.jpg]
[Image: http://i863.photobucket.com/albums/ab191...-501-1.jpg]
Larry
Recent pickups - 49-501 and a 40-150 - by rocketeer - 05-26-2011, 05:03 PM
Philco 91 Tuning Condenser
