PHILCO 48-482 4th IF Can
Is an isolating resistor of at least 10k used in between the generator and the inductor? I use 50K but my gear is older than the radios.
Try warming the coils with a heat gun, enough to make the wax fluid then let it cool. That should drive off any moisture, check again. If all fails time to shop for a replacement transformer.
Chas WA1JFD
Pliny the younger
PHILCO 48-482 4th IF Can - by W1ZY - 10-19-2022, 10:15 PM
RE: PHILCO 482 4th IF Can - by Chas - 10-20-2022, 12:42 AM
RE: PHILCO 482 4th IF Can - by W1ZY - 10-20-2022, 12:45 PM
RE: PHILCO 482 4th IF Can - by W1ZY - 10-20-2022, 02:31 PM
RE: PHILCO 482 4th IF Can - by Chas - 10-20-2022, 06:53 PM
RE: PHILCO 482 4th IF Can - by Radioroslyn - 10-20-2022, 07:31 PM
RE: PHILCO 482 4th IF Can - by Chas - 10-20-2022, 08:42 PM
91H Code 126 Restore
