Philco Model 81B
Hello George,
One thing I seen that helps is to use color highlight pens of diffrent colors and trace the wiring on the schematic !.
I will even use masking tape to make diffrent parts in the set .
Far as the coil that you repaired did you rewind new wire on the coil form and if so did you use the same gauge and lenght ?
Philco Model 81B - by texan george - 09-25-2022, 03:36 PM
RE: Philco Model 81B - by Radioroslyn - 09-25-2022, 07:49 PM
RE: Philco Model 81B - by David - 09-25-2022, 08:14 PM
RE: Philco Model 81B - by texan george - 09-25-2022, 08:24 PM
RE: Philco Model 81B - by texan george - 09-30-2022, 04:51 PM
RE: Philco Model 81B - by Radioroslyn - 09-30-2022, 10:32 PM
RE: Philco Model 81B - by texan george - 10-01-2022, 05:16 PM
RE: Philco Model 81B - by MrFixr55 - 10-01-2022, 05:40 PM
RE: Philco Model 81B - by Radioroslyn - 10-02-2022, 08:18 AM
RE: Philco Model 81B - by texan george - 10-02-2022, 08:42 AM
RE: Philco Model 81B - by falcon123 - 10-02-2022, 09:49 AM
RE: Philco Model 81B - by texan george - 10-02-2022, 01:05 PM
RE: Philco Model 81B - by Radioroslyn - 10-02-2022, 02:36 PM
RE: Philco Model 81B - by texan george - 10-02-2022, 05:05 PM
RE: Philco Model 81B - by Radioroslyn - 10-02-2022, 06:13 PM
RE: Philco Model 81B - by texan george - 10-03-2022, 01:17 PM
RE: Philco Model 81B - by radiorich - 10-03-2022, 02:30 PM
RE: Philco Model 81B - by texan george - 10-04-2022, 05:09 PM
RE: Philco Model 81B - by MrFixr55 - 10-04-2022, 10:12 PM
RE: Philco Model 81B - by texan george - 10-05-2022, 07:27 AM
RE: Philco Model 81B - by texan george - 10-21-2022, 02:55 PM
RE: Philco Model 81B - by radiorich - 10-21-2022, 03:24 PM
RE: Philco Model 81B - by Radioroslyn - 10-21-2022, 04:34 PM
RE: Philco Model 81B - by texan george - 10-22-2022, 06:26 AM
RE: Philco Model 81B - by texan george - 10-22-2022, 06:28 AM
RE: Philco Model 81B - by texan george - 10-22-2022, 02:19 PM
RE: Philco Model 81B - by texan george - 10-22-2022, 03:52 PM
RE: Philco Model 81B - by Radioroslyn - 10-22-2022, 08:43 PM
RE: Philco Model 81B - by Radioroslyn - 10-22-2022, 08:50 PM
RE: Philco Model 81B - by texan george - 10-23-2022, 04:45 PM
RE: Philco Model 81B - by Radioroslyn - 10-23-2022, 09:22 PM
RE: Philco Model 81B - by texan george - 10-25-2022, 05:46 PM
RE: Philco Model 81B - by texan george - 11-04-2022, 11:25 AM
RE: Philco Model 81B - by Radioroslyn - 11-04-2022, 12:58 PM
RE: Philco Model 81B - by RodB - 11-05-2022, 09:18 AM
RE: Philco Model 81B - by radiorich - 11-05-2022, 11:49 AM
RE: Philco Model 81B - by texan george - 11-05-2022, 03:26 PM
RE: Philco Model 81B - by texan george - 11-08-2022, 12:48 PM
RE: Philco Model 81B - by radiorich - 11-09-2022, 02:00 PM
RE: Philco Model 81B - by texan george - 11-10-2022, 12:09 PM
There are currently 4863 online users. [Complete List]
» 1 Member(s) | 4862 Guest(s)
