Philco resistors
Hello Tucker,
Well I personally only replace the resistors that are bad !
The very early ones are called Dog Bone resistors because their shaped like a dog bone .
Philco resistors - by Tucker - 10-22-2022, 09:14 AM
RE: Philco resistors - by radiorich - 10-22-2022, 12:34 PM
RE: Philco resistors - by GarySP - 10-22-2022, 04:36 PM
RE: Philco resistors - by David - 10-22-2022, 07:32 PM
RE: Philco resistors - by morzh - 10-23-2022, 04:28 PM
91H Code 126 Restore
There are currently 4905 online users. [Complete List]
» 1 Member(s) | 4904 Guest(s)
