Philco resistors
I only replace those badly out of tolerance.
Those within 50% I parallel with a newer one, hidden under the original.
Those within 25% I simply ignore.
Philco resistors - by Tucker - 10-22-2022, 09:14 AM
RE: Philco resistors - by radiorich - 10-22-2022, 12:34 PM
RE: Philco resistors - by GarySP - 10-22-2022, 04:36 PM
RE: Philco resistors - by David - 10-22-2022, 07:32 PM
RE: Philco resistors - by morzh - 10-23-2022, 04:28 PM
The speaker table error?
Philco 70 antenna lead
