Philco 40-180 Volume
Hi and welcome to the Phorum,
I would check #13 the plate choke for the rf amp isn't open and that the loop ant is connected properly.
Here's the Philco service info for your set. https://philcoradio.com/library/download...20Book.pdf
Philco 40-180 Volume - by gdolph - 10-24-2022, 06:45 PM
RE: Philco 40-180 Volume - by Radioroslyn - 10-24-2022, 08:17 PM
RE: Philco 40-180 Volume - by radiorich - 10-24-2022, 08:24 PM
RE: Philco 40-180 Volume - by morzh - 10-24-2022, 09:29 PM
The speaker table error?
Philco 70 antenna lead
