Philco 40-180 Volume
Hello gdolph,
welcome aboard and I agree with terry and I would also Add they might need some alighment too !
Philco 40-180 Volume - by gdolph - 10-24-2022, 06:45 PM
RE: Philco 40-180 Volume - by Radioroslyn - 10-24-2022, 08:17 PM
RE: Philco 40-180 Volume - by radiorich - 10-24-2022, 08:24 PM
RE: Philco 40-180 Volume - by morzh - 10-24-2022, 09:29 PM
The speaker table error?
Philco 70 antenna lead
