Philco 89 bypass capacitor voltage
Hi again, Mark.
Next time buy all 630v caps and this will never again be a question! A few cents more but at the price for shipping when you only need onesie-twosies you'll be better off in the long run.
Re: Philco 89 bypass capacitor voltage - by exray - 05-27-2011, 09:55 AM
Re: Philco 89 bypass capacitor voltage - by exray - 05-27-2011, 05:36 PM
Re: Philco 89 bypass capacitor voltage - by exray - 05-27-2011, 07:12 PM
The speaker table error?
Philco 70 antenna lead
