Philco 16B restoration
Rich
Somehow the 37-116, 38-690 and some other radios I have with 45rpm spiders survived just fine.
This is the 1st one I see like this.
Philco 16B restoration - by morzh - 08-07-2022, 02:27 PM
RE: Philco 16B restoration - by Radioroslyn - 08-07-2022, 06:49 PM
RE: Philco 16B restoration - by morzh - 10-09-2022, 09:11 PM
RE: Philco 16B restoration - by klondike98 - 10-09-2022, 09:38 PM
RE: Philco 16B restoration - by Radioroslyn - 10-09-2022, 10:00 PM
RE: Philco 16B restoration - by morzh - 10-09-2022, 10:16 PM
RE: Philco 16B restoration - by morzh - 10-11-2022, 08:28 PM
RE: Philco 16B restoration - by morzh - 10-15-2022, 09:37 PM
RE: Philco 16B restoration - by morzh - 10-16-2022, 09:52 PM
RE: Philco 16B restoration - by morzh - 10-17-2022, 08:36 PM
RE: Philco 16B restoration - by morzh - 10-19-2022, 09:13 PM
RE: Philco 16B restoration - by morzh - 10-20-2022, 07:51 PM
RE: Philco 16B restoration - by morzh - 10-23-2022, 07:04 PM
RE: Philco 16B restoration - by morzh - 10-26-2022, 02:03 PM
RE: Philco 16B restoration - by Radioroslyn - 10-26-2022, 02:12 PM
RE: Philco 16B restoration - by morzh - 10-26-2022, 10:33 PM
RE: Philco 16B restoration - by radiorich - 10-26-2022, 11:04 PM
RE: Philco 16B restoration - by morzh - 10-27-2022, 07:01 PM
RE: Philco 16B restoration - by morzh - 10-28-2022, 10:05 PM
RE: Philco 16B restoration - by morzh - 12-18-2022, 02:26 PM
RE: Philco 16B restoration - by Paul Philco322 - 12-18-2022, 05:00 PM
RE: Philco 16B restoration - by morzh - 12-18-2022, 05:29 PM
RE: Philco 16B restoration - by morzh - 12-29-2022, 03:58 PM
RE: Philco 16B restoration - by MrFixr55 - 12-29-2022, 07:30 PM
RE: Philco 16B restoration - by morzh - 12-29-2022, 08:27 PM
Philco 91 Tuning Condenser
