Philco 40-180 Compensator Alignment
Hi gdolph, in post #21 you state that you can receive stations at 1060, 1100, 660 and 700 at the correct spot on the dial. If you can’t pickup the 580 and 1400kc from your signal generator perhaps there’s a problem with your test setup or the generator itself. If those stations you mentioned are coming at the correct spot on the dial I wouldn’t mess with the oscillator alignment but instead concentrate on the RF alignment and associated circuitry including coils and switch contacts as already mentioned. GL
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Philco 40-180 Compensator Alignment - by tludka - 03-16-2022, 08:31 PM
RE: Philco 40-180 Compensator Alignment - by RodB - 10-28-2022, 10:12 AM
RE: Philco 40-180 Compensator Alignment - by RodB - 10-28-2022, 09:32 PM
462ron - by 462ron - 10-29-2022, 08:11 AM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 2750 online users. [Complete List]
» 2 Member(s) | 2748 Guest(s)
