38-116 Code 121 vs Code 125 - Long Topic!
Ron Ramirez Wrote:I no longer own any of these models, so I can't do the side-by-side analysis. So...we're relying on you, Ed. Icon_smile
OK Ron, will do. It may be a while though, as I have quite a few radios before these in the queue.
Ed
Re: 38-116 Code 121 vs Code 125 - Long Topic! - by etech - 05-28-2011, 09:59 PM
