Philco Clock Timer Help
Have you opened it up and had a look inside? More then likely the mechanism is seized up from disuse so I would not leave it plugged in too long. Perhps someone on the alternative forum, in the communications set area might know what it's for, or have more information.
Philco Clock Timer Help - by tonycrouch1183 - 11-03-2022, 03:41 PM
RE: Philco Clock Timer Help - by tonycrouch1183 - 11-08-2022, 02:56 PM
RE: Philco Clock Timer Help - by klondike98 - 11-08-2022, 04:26 PM
RE: Philco Clock Timer Help - by Brad Winder - 11-08-2022, 10:19 PM
RE: Philco Clock Timer Help - by Arran - 11-09-2022, 06:26 AM
RE: Philco Clock Timer Help - by tonycrouch1183 - 11-23-2022, 09:43 AM
RE: Philco Clock Timer Help - by David - 11-23-2022, 08:50 PM
RE: Philco Clock Timer Help - by radio63 - 01-11-2023, 03:23 AM
RE: Philco Clock Timer Help - by David - 01-11-2023, 02:12 PM
Eico 232 VTVM Schematic
There are currently 6542 online users. [Complete List]
» 3 Member(s) | 6539 Guest(s)
