PHILCO 20 - VOLUME
Hello,
I have put two resistors: 2K2 and 1K8. And volume working.
Thank you!!
Icon_biggrin Icon_biggrin Icon_biggrin Icon_biggrin
PHILCO 20 - VOLUME - by ducretet - 11-08-2022, 02:24 PM
RE: PHILCO 20 - VOLUME - by Radioroslyn - 11-08-2022, 04:04 PM
RE: PHILCO 20 - VOLUME - by ducretet - 11-09-2022, 03:28 AM
RE: PHILCO 20 - VOLUME - by Radioroslyn - 11-09-2022, 10:51 AM
RE: PHILCO 20 - VOLUME - by ducretet - 11-09-2022, 12:55 PM
RE: PHILCO 20 - VOLUME - by radiorich - 11-09-2022, 01:53 PM
RE: PHILCO 20 - VOLUME - by Radioroslyn - 11-09-2022, 02:04 PM
RE: PHILCO 20 - VOLUME - by ducretet - 11-09-2022, 03:56 PM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 2746 online users. [Complete List]
» 2 Member(s) | 2744 Guest(s)
