Philco Canada 53A s
Lar,
According to Ron's 2nd edition Philco Radio guide the Canadian Philco 53AX is a 1942 model with no U.S. equivalent. It lists this as a 6 tube AC radio? Obviously you have a seven tube unit!
The plug may be the old speaker plug for an original electrodynamic speaker...may be the existing speaker was a changeout as the audio output transformer is mounted next to the chassis? Schematics can be had from Just Radios. Looks like a nice radio. Icon_smile
Good luck, John
Philco Canada 53A s - by diamondsouled - 05-29-2011, 09:38 PM
Re: Philco Canada 53A s - by John R - 05-29-2011, 11:35 PM
Re: Philco Canada 53A s - by diamondsouled - 05-29-2011, 11:41 PM
Re: Philco Canada 53A s - by John R - 06-01-2011, 01:27 PM
Re: Philco Canada 53A s - by Arran - 06-01-2011, 11:53 PM
Re: Philco Canada 53A s - by Arran - 06-02-2011, 12:38 AM
Re: Philco Canada 53A s - by Carl Travis - 06-02-2011, 09:07 AM
Re: Philco Canada 53A s - by John R - 06-02-2011, 09:06 PM
Re: Philco Canada 53A s - by 7estatdef - 06-02-2011, 09:43 PM
Re: Philco Canada 53A s - by diamondsouled - 06-03-2011, 04:34 PM
Re: Philco Canada 53A s - by diamondsouled - 06-03-2011, 05:36 PM
Re: Philco Canada 53A s - by John R - 06-05-2011, 01:58 PM
Re: Philco Canada 53A s - by diamondsouled - 06-06-2011, 11:24 AM
Re: Philco Canada 53A s - by Arran - 06-08-2011, 11:37 PM
There are currently 4277 online users. [Complete List]
» 2 Member(s) | 4275 Guest(s)
