Philco Model 89 - 123
Those Bullet style sets have a certain something, neat design. I had a Stewart Warner that had that type of a case, did not keep it but looked better than it played......good luck all. I only have 1 Philco Cathredral set....what every layman thinks of when somebody sez "Old Radio".
Philco Model 89 - 123 - by mikethedruid - 11-14-2022, 09:52 PM
RE: Philco Model 89 - 123 - by radiorich - 11-14-2022, 11:01 PM
RE: Philco Model 89 - 123 - by mikethedruid - 11-15-2022, 12:46 AM
RE: Philco Model 89 - 123 - by Brad Winder - 11-15-2022, 10:56 AM
RE: Philco Model 89 - 123 - by Paul Philco322 - 11-15-2022, 11:12 AM
RE: Philco Model 89 - 123 - by Simon Wa3uay - 11-16-2022, 06:49 PM
RE: Philco Model 89 - 123 - by mikethedruid - 11-18-2022, 01:30 AM
RE: Philco Model 89 - 123 - by radiorich - 11-18-2022, 10:21 AM
RE: Philco Model 89 - 123 - by mikethedruid - 11-19-2022, 12:33 AM
