philco 38-8 back wood or cardboard ??
No built-in antenna according to the schematic.
Re: philco 38-8 back wood or cardboard ?? - by exray - 05-30-2011, 05:58 PM
There are currently 10533 online users. [Complete List]
» 4 Member(s) | 10529 Guest(s)
AvatarAvatarAvatarAvatar
