Philco Clock Timer Help
Tried looking up the contract number no luck the serial number is 21, maybe not many built. Might try some of the military forums that get into old stuff. Have a signal corp genset from 1954 was able to get a PDF of the TM. Looking inside you might find some info or at least who made some of the parts. Good luck an let us know what you find. David
Philco Clock Timer Help - by tonycrouch1183 - 11-03-2022, 03:41 PM
RE: Philco Clock Timer Help - by tonycrouch1183 - 11-08-2022, 02:56 PM
RE: Philco Clock Timer Help - by klondike98 - 11-08-2022, 04:26 PM
RE: Philco Clock Timer Help - by Brad Winder - 11-08-2022, 10:19 PM
RE: Philco Clock Timer Help - by Arran - 11-09-2022, 06:26 AM
RE: Philco Clock Timer Help - by tonycrouch1183 - 11-23-2022, 09:43 AM
RE: Philco Clock Timer Help - by David - 11-23-2022, 08:50 PM
RE: Philco Clock Timer Help - by radio63 - 01-11-2023, 03:23 AM
RE: Philco Clock Timer Help - by David - 01-11-2023, 02:12 PM
Eico 232 VTVM Schematic
There are currently 6858 online users. [Complete List]
» 2 Member(s) | 6856 Guest(s)
