Your expierience in $$ for DIY restoration? Newbie w/41-608
Thank you Ron. Obviously this is going to be my first restoration attempt. I have a basic understanding of capacitors, fuses, soldering, heat shrink tubing, etc., from working for Grainger for the past 14 years. But knowing about these things and actually using them are 2 different things.
I certainly don't mind the work. It will be a labor of love for sure.
Kathy
The speaker table error?
Philco 70 antenna lead
