Stewart-Warner A72T3
It's been while since I worked on this radio.
I checked all the tubes again and they tested all ok. So I started checking all the circuits to make sure everything was correct when I noticed two plates were touching on the tuning condenser. After I straighten out the plates the FM works but only getting two stations. The two stations come in strong but only two.
I also noticed when I turn on the radio the bulb gets very bright then dims down. I measured the voltage at the bulb and its 2.9 V
Schematic is up in the very 1st post
Stewart-Warner A72T3 - by Masonparker - 07-23-2022, 01:32 PM
RE: Stewart-Warner A72T3 - by Paul Philco322 - 07-23-2022, 01:45 PM
RE: Stewart-Warner A72T3 - by David - 07-23-2022, 04:54 PM
RE: Stewart-Warner A72T3 - by RodB - 07-23-2022, 05:30 PM
RE: Stewart-Warner A72T3 - by morzh - 07-23-2022, 07:27 PM
RE: Stewart-Warner A72T3 - by Masonparker - 07-23-2022, 08:33 PM
RE: Stewart-Warner A72T3 - by Radioroslyn - 07-23-2022, 08:56 PM
RE: Stewart-Warner A72T3 - by David - 07-23-2022, 09:17 PM
RE: Stewart-Warner A72T3 - by MrFixr55 - 07-23-2022, 09:22 PM
RE: Stewart-Warner A72T3 - by Masonparker - 07-24-2022, 06:54 AM
RE: Stewart-Warner A72T3 - by morzh - 07-24-2022, 10:19 AM
RE: Stewart-Warner A72T3 - by Masonparker - 07-29-2022, 04:19 PM
RE: Stewart-Warner A72T3 - by Radioroslyn - 07-30-2022, 08:01 AM
RE: Stewart-Warner A72T3 - by Masonparker - 11-29-2022, 10:07 PM
