Philco 84 Electrolytic
Yup you got it. The - side goes to the 325 ohm wire wound resistor/high voltage center tap. The +'s go to the 16K and the filament of the 80 tube. Don't know if you are a diagram reader, the filter caps +'s are on the top and -'s are bottom.
Sorry to confuse. A lot of the Philco e caps a metal tab that slips in between the can and the cardboard insulator. This is where the - connection is made. Yours is a little different. Not wrong as I looked at one of my 84 and it looks just like yours. My mistake.
https://philcoradio.com/library/download...%20178.pdf
Philco 84 Electrolytic - by Ralph - 12-01-2022, 02:45 PM
RE: Philco 84 Electrolytic - by Radioroslyn - 12-01-2022, 04:50 PM
RE: Philco 84 Electrolytic - by Ralph - 12-01-2022, 07:45 PM
RE: Philco 84 Electrolytic - by morzh - 12-01-2022, 09:24 PM
RE: Philco 84 Electrolytic - by Ralph - 12-02-2022, 01:47 PM
RE: Philco 84 Electrolytic - by Radioroslyn - 12-02-2022, 04:13 PM
RE: Philco 84 Electrolytic - by radiorich - 12-02-2022, 08:26 PM
RE: Philco 84 Electrolytic - by Ralph - 12-02-2022, 09:01 PM
RE: Philco 84 Electrolytic - by radiorich - 12-03-2022, 01:52 PM
RE: Philco 84 Electrolytic - by Ralph - 12-18-2022, 08:40 AM
462ron - by 462ron - 12-18-2022, 09:26 AM
RE: Philco 84 Electrolytic - by Radioroslyn - 12-18-2022, 10:51 AM
RE: Philco 84 Electrolytic - by Ralph - 12-19-2022, 05:01 PM
RE: Philco 84 Electrolytic - by RodB - 12-19-2022, 06:54 PM
RE: Philco 84 Electrolytic - by Ralph - 12-19-2022, 08:05 PM
There are currently 7339 online users. [Complete List]
» 2 Member(s) | 7337 Guest(s)
