89PHILCO
There are really only two places that carry true reproductions of radio grille cloth. Most fabrics you find "online" are unsuitable for use as grille cloth due to tightness of weave and also ugliness!
https://www.radiogrillecloth.com
http://www.richmonddesignsinc.com/introduction_page
The closest you'll find for that cloth currently would be the Philco 70/90 cloth that Michael Katz sells (radiogrillecloth)
89PHILCO - by Bradley Rush - 11-30-2022, 02:24 AM
RE: 89PHILCO - by GarySP - 11-30-2022, 10:44 AM
RE: 89PHILCO - by Brad Winder - 11-30-2022, 11:26 AM
RE: 89PHILCO - by GarySP - 11-30-2022, 12:26 PM
RE: 89PHILCO - by Bradley Rush - 12-03-2022, 01:39 PM
RE: 89PHILCO - by Bradley Rush - 12-03-2022, 01:52 PM
RE: 89PHILCO - by Bradley Rush - 12-03-2022, 01:55 PM
RE: 89PHILCO - by RodB - 12-03-2022, 02:00 PM
RE: 89PHILCO - by Brad Winder - 12-03-2022, 02:30 PM
RE: 89PHILCO - by Brad Winder - 12-03-2022, 02:45 PM
RE: 89PHILCO - by Brad Winder - 12-03-2022, 03:13 PM
RE: 89PHILCO - by Bradley Rush - 12-03-2022, 05:48 PM
RE: 89PHILCO - by radiorich - 12-03-2022, 10:07 PM
RE: 89PHILCO - by Bradley Rush - 12-06-2022, 12:46 AM
RE: 89PHILCO - by Bradley Rush - 12-06-2022, 12:48 AM
RE: 89PHILCO - by radiorich - 12-06-2022, 01:52 AM
RE: 89PHILCO - by Bradley Rush - 12-12-2022, 09:07 PM
RE: 89PHILCO - by Bradley Rush - 12-12-2022, 09:10 PM
RE: 89PHILCO - by Bradley Rush - 12-12-2022, 09:11 PM
RE: 89PHILCO - by GarySP - 12-13-2022, 09:16 AM
Philco 91 Tuning Condenser
There are currently 8311 online users. [Complete List]
» 2 Member(s) | 8309 Guest(s)
