Philco 40-88 chassis wiring pictures
Or
I think they all come from the same place...
The power switch is pretty standard fair for a battery set. It disconnects the A+ and the B+. This insures no battery drain when the set is off.
RE: Philco 40-88 chassis wiring pictures - by Radioroslyn - 12-03-2022, 08:42 PM
There are currently 5874 online users. [Complete List]
» 2 Member(s) | 5872 Guest(s)
