Can someone identify this radio?
I have this radio, it works excellent in original condition.  Sadly the model # is missing.  Everything inside is dated 1965 though
Can someone identify this radio? - by bribieboy - 01-18-2013, 09:02 AM
RE: Can someone identify this radio? - by Mechanism - 12-04-2022, 12:12 PM
RE: Can someone identify this radio? - by morzh - 12-04-2022, 12:58 PM
RE: Can someone identify this radio? - by Jayce - 12-05-2022, 11:29 PM
Philco 91 Tuning Condenser
There are currently 8984 online users. [Complete List]
» 3 Member(s) | 8981 Guest(s)
