newbee cant read wiring for 84b early..!
OK well the only other thing that connects to that part of the circuit is whats call a gimmick capacitor. According to the schematic it should be wired in at pins 4 or 5 of the 77 socket. That connection that the coil were that wire comes from is just a tie point as the windings are only connected to the other two posts the other two ends of the windings are connected to the coil bracket thus grounded.
Anyway the gimmick cap is just two wires twisted together with the insulation intact. The bare wire must not come in contact with each other. The other wire comes from the center post of the volume control. If remember right seems like I seen the wire rapped around the VC wire about 2 or 3 turns.
Good luck w/ it
Re: newbee cant read wiring for 84b early..! - by 7estatdef - 08-10-2011, 07:10 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6308 online users. [Complete List]
» 2 Member(s) | 6306 Guest(s)
