Philco 610 Resisters Question
Thanks David but you didn’t actually answer any of my questions. Whether #39 and #40 should be reversed, what the wattage should be and whether the #42 should be a 32K.
The 20 mfd is just there to remind me where it was connected to those three resisters.
No offense and I appreciate the prompt response but I was hoping for a little more clarity.
Philco 610 Resisters Question - by Hamilton - 12-10-2022, 05:50 PM
RE: Philco 610 Resisters Question - by David - 12-10-2022, 06:19 PM
RE: Philco 610 Resisters Question - by Hamilton - 12-10-2022, 08:52 PM
RE: Philco 610 Resisters Question - by David - 12-10-2022, 09:56 PM
RE: Philco 610 Resisters Question - by radiorich - 12-10-2022, 11:28 PM
RE: Philco 610 Resisters Question - by Hamilton - 12-11-2022, 05:37 PM
Philco 91 Tuning Condenser
There are currently 9038 online users. [Complete List]
» 1 Member(s) | 9037 Guest(s)
