Philco 610 Resisters Question
Hello Hamilton,
What a great Project I restored a Philco 610B many years ago and it works great
When I restored mine I stuffed the electrolytic capacitors into the original Cans !
Yes 1watt is what I used to replace mine too .
Philco 610 Resisters Question - by Hamilton - 12-10-2022, 05:50 PM
RE: Philco 610 Resisters Question - by David - 12-10-2022, 06:19 PM
RE: Philco 610 Resisters Question - by Hamilton - 12-10-2022, 08:52 PM
RE: Philco 610 Resisters Question - by David - 12-10-2022, 09:56 PM
RE: Philco 610 Resisters Question - by radiorich - 12-10-2022, 11:28 PM
RE: Philco 610 Resisters Question - by Hamilton - 12-11-2022, 05:37 PM
There are currently 5949 online users. [Complete List]
» 1 Member(s) | 5948 Guest(s)
