Philco 610 Resisters Question
Hi all, I did reverse what the owner before me had done with the #39 and #40 resisters. I then fired it up on my dim bulb and it was receiving stations. I’ll do the rest of the bakelite blocks and out of value resistors and see how it sounds then.
Philco 610 Resisters Question - by Hamilton - 12-10-2022, 05:50 PM
RE: Philco 610 Resisters Question - by David - 12-10-2022, 06:19 PM
RE: Philco 610 Resisters Question - by Hamilton - 12-10-2022, 08:52 PM
RE: Philco 610 Resisters Question - by David - 12-10-2022, 09:56 PM
RE: Philco 610 Resisters Question - by radiorich - 12-10-2022, 11:28 PM
RE: Philco 610 Resisters Question - by Hamilton - 12-11-2022, 05:37 PM
