I finally got my Rogers 10-12 power supply
It has been about five years of looking , but I finally got the power supply for one of my Rogers 10-12 radios.
     I have already recapped the radio and the cabinet is original and quite good.
I have recapped the power supply and everything looks good
It will be a while before I get things together.
I am taking the clock out of my Rogers 4821 radio [the clock is on the side] and putting it in the 10-12
 Dan in Calgary
   Living in Calgary Alberta
I finally got my Rogers 10-12 power supply - by Dan Walker - 12-17-2022, 11:30 AM
