I finally got my Rogers 10-12 power supply
I guess it isn't a winter project,because   I recapped the chassis about two years ago  and at that time it was playing OK.
     I will put it on the bench and make sure it works, then I have to wait until spring to get it all together.
I don't have a heated garage.
 Here is a question
  Can I power up the power supply with the rectifier tube in,   if it is not plugged into the radio chassis.  I just don't want any surprises when I plug it into the radio?
 Dan in Calgary
   Living in Calgary Alberta
RE: I finally got my Rogers 10-12 power supply - by Dan Walker - 12-17-2022, 03:30 PM
