Philco 16B restoration
Has been a while.
The speaker came back from Rich Stamer.
Can't wait to hear it converting electrical signal to acoustic waves. Icon_lol
It took Rich a bit as he was going through hip replacement. He is feeling good, going through physical therapy and moving about, doing work on speakers. Even though he said he was pushing all the work 'till February, mine got done nevertheless.
So hopefully today I will assemble the whole thing together as the chassis's been taken care of.
Philco 16B restoration - by morzh - 08-07-2022, 02:27 PM
RE: Philco 16B restoration - by Radioroslyn - 08-07-2022, 06:49 PM
RE: Philco 16B restoration - by morzh - 10-09-2022, 09:11 PM
RE: Philco 16B restoration - by klondike98 - 10-09-2022, 09:38 PM
RE: Philco 16B restoration - by Radioroslyn - 10-09-2022, 10:00 PM
RE: Philco 16B restoration - by morzh - 10-09-2022, 10:16 PM
RE: Philco 16B restoration - by morzh - 10-11-2022, 08:28 PM
RE: Philco 16B restoration - by morzh - 10-15-2022, 09:37 PM
RE: Philco 16B restoration - by morzh - 10-16-2022, 09:52 PM
RE: Philco 16B restoration - by morzh - 10-17-2022, 08:36 PM
RE: Philco 16B restoration - by morzh - 10-19-2022, 09:13 PM
RE: Philco 16B restoration - by morzh - 10-20-2022, 07:51 PM
RE: Philco 16B restoration - by morzh - 10-23-2022, 07:04 PM
RE: Philco 16B restoration - by morzh - 10-26-2022, 02:03 PM
RE: Philco 16B restoration - by Radioroslyn - 10-26-2022, 02:12 PM
RE: Philco 16B restoration - by morzh - 10-26-2022, 10:33 PM
RE: Philco 16B restoration - by radiorich - 10-26-2022, 11:04 PM
RE: Philco 16B restoration - by morzh - 10-27-2022, 07:01 PM
RE: Philco 16B restoration - by morzh - 10-28-2022, 10:05 PM
RE: Philco 16B restoration - by morzh - 12-18-2022, 02:26 PM
RE: Philco 16B restoration - by Paul Philco322 - 12-18-2022, 05:00 PM
RE: Philco 16B restoration - by morzh - 12-18-2022, 05:29 PM
RE: Philco 16B restoration - by morzh - 12-29-2022, 03:58 PM
RE: Philco 16B restoration - by MrFixr55 - 12-29-2022, 07:30 PM
RE: Philco 16B restoration - by morzh - 12-29-2022, 08:27 PM
Philco 91 Tuning Condenser
There are currently 9282 online users. [Complete List]
» 1 Member(s) | 9281 Guest(s)
