Philco model 96
has anyone measured the inductance of the model H speaker field coil? would like to replace the speaker assembly with a newer one but want to use a replacement inductor.
Philco model 96 - by kcub7 - 12-20-2022, 07:35 PM
RE: Philco model 96 - by morzh - 12-20-2022, 08:56 PM
Eico 232 VTVM Schematic
There are currently 9305 online users. [Complete List]
» 2 Member(s) | 9303 Guest(s)
