Empty cabinet?
I found a Philco 60-505 cabinet only in my father's storage unit after he passed away. It is in bad shape, with peeling veneer and the legs have some wood missing. Also, as said before, it has no insides, it is only the empty cabinet.
My question is would anybody even want this? or should I just junk it? If someone would possibly want to buy this item, what would a fair price be?
Thank you.
Empty cabinet? - by rwights - 06-01-2011, 01:22 PM
Re: Empty cabinet? - by Ron Ramirez - 06-01-2011, 01:37 PM
There are currently 9862 online users. [Complete List]
» 1 Member(s) | 9861 Guest(s)
