IF Transformer open 46-1203
I have a 46-1203 Radio portion primary of the IF can was open (no voltage on plate there) so I opened it up and could not find the wire to reconnect. Unwound it and re wound but I realised that is not right because turns ratio matters more than DC resistance. Anyway there are 2 part numbers on it.
32-4005 and 39-8061. Is there a cross reference to another type?
Are there any subtitutes or can I use another type to put in? It has 5 wires coming out of it.
What are my options. I cannot get anything out of it as is.
THX
IF Transformer open 46-1203 - by BUbba - 06-01-2011, 03:09 PM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-02-2011, 06:45 AM
Re: IF Transformer open 46-1203 - by BUbba - 06-03-2011, 10:34 AM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-03-2011, 05:20 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-03-2011, 08:47 PM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-04-2011, 07:06 PM
Re: IF Transformer open 46-1203 - by Ron Ramirez - 06-04-2011, 09:05 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-07-2011, 12:56 AM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-07-2011, 07:45 AM
Re: IF Transformer open 46-1203 - by BUbba - 06-22-2011, 09:43 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-22-2011, 09:54 PM
Re: IF Transformer open 46-1203 - by 7estatdef - 06-23-2011, 06:03 PM
Re: IF Transformer open 46-1203 - by BUbba - 06-23-2011, 11:22 PM
