Philco 2620B Escutcheon
Hello,
I'm from Belgium and speak Dutch.I will do my best to express myself in English.
I own a Philco 2620B radio which I would restore soon.The only problem is the escutcheon : the glass is still in great condition(no scratches) but the design (drawing) is missing in some places.
So, I'm looking for a good scan of the dial glass with the design to print it out on decal paper or with overhead transparancy paper to make a replacement.
Can someone help me?
Kind regards, Icon_smile Karel
[attachment=1] [attachment=0]
Philco 2620B Escutcheon - by Karel - 06-01-2011, 03:49 PM
Re: Philco 2620B Escutcheon - by 7estatdef - 06-01-2011, 10:32 PM
Re: Philco 2620B Escutcheon - by Karel - 06-02-2011, 06:34 AM
Re: Philco 2620B Escutcheon - by Ron Ramirez - 06-04-2011, 09:24 PM
Re: Philco 2620B Escutcheon - by Karel - 06-05-2011, 01:55 PM
There are currently 8176 online users. [Complete List]
» 1 Member(s) | 8175 Guest(s)
