Anyone able to identify this radio?
That series of chassis were used in a number of cabinets, there was even a battery version (at least on the Canadian market) same layout but no rectifier tube socket. I have two of the battery versions downstairs, in wood cabinets, and an AC/DC in Bakelite cabinet, the batter sets do not have Transitone market on the dial. Mixing an matching does not surprise me as swapping one chassis into another was basically bolt in.
RE: Anyone able to identify this radio? - by Arran - 12-31-2022, 02:13 PM
