Bakelite block value in a 46-1201 turntable
Went to the Post Office this morning and now have the book. Not sure when it arrived as I only check my mail once maybe twice a week. Think I will order some more of his books. Take Care David
There are currently 9218 online users. [Complete List]
» 2 Member(s) | 9216 Guest(s)
