Long 41-255 Story
I had the exact symptom with a 41-255. It turned out to be a bad 250 pf mica capacitor (nuumber 24 on the Rider schematic) connected to the grid of the XXL oscillator.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Long 41-255 Story - by calmark - 05-17-2006, 08:41 PM
[No subject] - by Terry Judkins - 05-17-2006, 10:05 PM
Long 41-255 Story Part 2 - by calmark - 05-18-2006, 05:12 PM
There are currently 3799 online users. [Complete List]
» 1 Member(s) | 3798 Guest(s)
