Philco 46-1201
Welcome to the Phorum!
Icon_wave
I'm not the best guy for troubleshooting so I'll leave that to others with more skills but for folks to follow along here's the link to the schematic in our library: https://philcoradio.com/library/download...6-1947.pdf [Link corrected...thanks]
Not sure what you mean when you say magnet less speaker.  These originally had an electrodynamic speaker which uses a field coil to create the magnetic field for the speaker.
Philco 46-1201 - by mjnormandin76@gmail.com - 01-06-2023, 12:19 PM
RE: Philco 46-1201 - by klondike98 - 01-06-2023, 02:27 PM
RE: Philco 46-1201 - by mjnormandin76@gmail.com - 01-06-2023, 02:49 PM
RE: Philco 46-1201 - by mjnormandin76@gmail.com - 01-06-2023, 02:58 PM
RE: Philco 46-1201 - by RodB - 01-06-2023, 03:32 PM
RE: Philco 46-1201 - by klondike98 - 01-06-2023, 04:52 PM
There are currently 9239 online users. [Complete List]
» 2 Member(s) | 9237 Guest(s)
