Philco 46-1201
Thank you.
That is correct, the speaker has a 1200 ohms coil to create the electro magnetic field... Just did not know the lingo for it.
Since the voltage is about 100, that coil gets pretty warn. Nevertheless, I do not get where that hum could be coming from. I even doubled the two 25 uf and the one 40 uf to see if it will reduce the hum... But no cigar.
Philco 46-1201 - by mjnormandin76@gmail.com - 01-06-2023, 12:19 PM
RE: Philco 46-1201 - by klondike98 - 01-06-2023, 02:27 PM
RE: Philco 46-1201 - by mjnormandin76@gmail.com - 01-06-2023, 02:49 PM
RE: Philco 46-1201 - by mjnormandin76@gmail.com - 01-06-2023, 02:58 PM
RE: Philco 46-1201 - by RodB - 01-06-2023, 03:32 PM
RE: Philco 46-1201 - by klondike98 - 01-06-2023, 04:52 PM
There are currently 7864 online users. [Complete List]
» 1 Member(s) | 7863 Guest(s)
