Philco 46-1201
Yes it is an elctrodinamic coil magnet. I did not know the terminology for it. Nevertheless, I changed all capacitor I could find and doubled the 40 uf and the two 25 uf capacitors just to see if it will reduce the hum and no cigar.
Philco 46-1201 - by mjnormandin76@gmail.com - 01-06-2023, 12:19 PM
RE: Philco 46-1201 - by klondike98 - 01-06-2023, 02:27 PM
RE: Philco 46-1201 - by mjnormandin76@gmail.com - 01-06-2023, 02:49 PM
RE: Philco 46-1201 - by mjnormandin76@gmail.com - 01-06-2023, 02:58 PM
RE: Philco 46-1201 - by RodB - 01-06-2023, 03:32 PM
RE: Philco 46-1201 - by klondike98 - 01-06-2023, 04:52 PM
There are currently 4811 online users. [Complete List]
» 1 Member(s) | 4810 Guest(s)
