Unknown 40-180 Switch/Jack
my guess is that great-grand-daddy made alterations to the radio.
Wilder guess is that the switch actually redirect the speaker to the jack, or something to that effect.
can you take pictures of the wiring?
-Mars
Unknown 40-180 Switch/Jack - by ROXCELLA - 06-02-2011, 09:42 PM
Re: Unknown 40-180 Switch/Jack - by Marsupial - 06-02-2011, 10:41 PM
Re: Unknown 40-180 Switch/Jack - by Chuck Schwark - 06-03-2011, 09:39 AM
Re: Unknown 40-180 Switch/Jack - by Marsupial - 06-03-2011, 10:06 AM
Re: Unknown 40-180 Switch/Jack - by Ron Ramirez - 06-04-2011, 09:14 PM
Re: Unknown 40-180 Switch/Jack - by rocketeer - 06-07-2011, 09:45 PM
Re: Unknown 40-180 Switch/Jack - by codefox1 - 06-08-2011, 12:28 AM
Re: Unknown 40-180 Switch/Jack - by rocketeer - 06-08-2011, 11:09 AM
Re: Unknown 40-180 Switch/Jack - by ROXCELLA - 06-08-2011, 06:22 PM
Eico 232 VTVM Schematic
There are currently 8927 online users. [Complete List]
» 1 Member(s) | 8926 Guest(s)
