Philco 90 found locally
Under chasiss does appear untouched by a restorer and eminently restoreable.
Even has the original Mershon copper electrolytics, no less!
(See the re-stuffing tips for these on my site.)
Unusually good condition. A keeper.
Chuck
Philco 90 found locally - by radioray - 07-12-2011, 04:26 PM
Re: Philco 90 found locally - by Chuck Schwark - 07-12-2011, 05:27 PM
Re: Philco 90 found locally - by Ron Ramirez - 07-12-2011, 05:56 PM
Re: Philco 90 found locally - by radioray - 07-12-2011, 06:52 PM
Re: Philco 90 found locally - by Uffda - 07-12-2011, 09:37 PM
Re: Philco 90 found locally - by 37silverstreak - 07-12-2011, 10:22 PM
Re: Philco 90 found locally - by Arran - 07-13-2011, 12:15 AM
Re: Philco 90 found locally - by Eliot Ness - 07-14-2011, 11:44 AM
Re: Philco 90 found locally - by radioray - 07-17-2011, 04:26 PM
Re: Philco 90 found locally - by codefox1 - 07-17-2011, 06:25 PM
Re: Philco 90 found locally - by Arran - 07-18-2011, 06:45 AM
Re: Philco 90 found locally - by Eliot Ness - 07-18-2011, 11:25 AM
Re: Philco 90 found locally - by Chuck Schwark - 07-18-2011, 03:24 PM
Re: Philco 90 found locally - by Eliot Ness - 07-18-2011, 05:04 PM
Re: Philco 90 found locally - by Chuck Schwark - 07-18-2011, 05:39 PM
Re: Philco 90 found locally - by TA Forbes - 07-19-2011, 10:35 PM
There are currently 9918 online users. [Complete List]
» 2 Member(s) | 9916 Guest(s)
