Tuner gear assembly...
Thanks MrFixr55... after regreasing it fine tuning didn't work reliably so ill reclean it and just use oil again.
i just use tap water and Purple Power from walmart, about half cup to 1/2 gallon water in my Harbor Freight unit.
Tuner gear assembly... - by promocom - 01-13-2023, 07:08 PM
RE: Tuner gear assembly... - by MrFixr55 - 01-13-2023, 11:51 PM
RE: Tuner gear assembly... - by promocom - 01-15-2023, 07:39 PM
RE: Tuner gear assembly... - by MrFixr55 - 01-17-2023, 05:06 AM
RE: Tuner gear assembly... - by promocom - 01-17-2023, 05:02 PM
RE: Tuner gear assembly... - by Simon Wa3uay - 01-18-2023, 07:08 PM
RE: Tuner gear assembly... - by promocom - 01-21-2023, 12:25 AM
There are currently 4509 online users. [Complete List]
» 1 Member(s) | 4508 Guest(s)
